Best All-Around Paddle Boards of 2022
From inflatables to hard boards, the gamut of All-Around Paddle Boards being offered in 2022 is remarkably complete. But how do you evaluate all of these SUPs and select the right choice for you, your experience, and planned paddling? Fortunately, your paddling friends have been hard at work. Here's the best all-around SUPs as paddled, tested, and reviewed by you!
So how do you evaluate your options and make a decision in 2022? To begin, you need to understand that an All-Around SUP is named appropriately. That is, an All-Around SUP is designed and intended to be used for all water types. Whereas other categories of SUP might be optimally designed for a specific water type or duration, all-around boards balance speed, stability, and tracking. If versatility and ease of use are your priorities, then an All-Around SUP is perfect for you.
Fortunately, the ever-growing SUP community has been paddling along and sharing their experiences through All-Around SUP reviews. By leveraging the reviews and experience that's been shared by thousands of your fellow paddlers, they've helped narrow the remarkable gamut of options down to the best of the best.
Considerations When Buying An All-Around SUP
An all-around board, generally speaking, is a great choice in SUP especially for those who are new to the sport or see themselves paddling mostly flat water. They're wider, thicker, and typically longer than a Surf SUP. But they're shorter and wider than a Touring SUP. They're designed to be the most versatile, all-purpose board which makes them the best choice if you're just getting into the sport because you can do everything with this one SUP.
Before you start evaluating All-Around SUP models and the many options, you need to consider a few different factors:
- Volume & Board Size - The most overlooked, but also one of the most important, factors is your size in relation to the board. Volume is a great way to think about a board size. There's a certain amount of volume inside any board. That volume is what floats you. So you need a board with a certain amount of volume so that you'll be comfortable out there and you won't be unstable.
- Width - Width is a big factor as it relates to SUP stability. As the board gets wider, you can expect it to be more stable. But as the board gets skinnier, it'll track straighter and faster. So you'll want to find a width that matches your preference for stability vs. speed and tracking.
- Length - Board length is important not only for the type of water you see yourself paddling (Flat water? Ocean? River?), but also for your planned distances and duration. The longer the board, the more glide you can expect and you can get more distance and cover more distance. But the shorter the board, the more conducive to that surf-style performance you can expect.
- Thickness - Board thickness is also often overlooked and misunderstood. The ideal thickness will depend on board material and whether you are looking for an inflatable SUP or a hard, rigid SUP. In general, you'll see and want your inflatables to be thicker than your hard, rigid board. Especially for inflatables, you want to make sure that the thickness and rigidity when inflated will be durable and perform for your entire duration.
Below we'll lay out a few of the absolute best All-Around SUPs to choose from. Rather than a single opinion, we've compiled this list using SUP reviews and experiences from thousands of paddlers just like you. So use this list as a starting point. Get some ideas, read some reviews, look through the entire All-Around SUP Gear Guide, maybe browse the message boards, talk to your local paddlesports retailer or paddling groups, and get out and try it before you buy it!
And, of course, when you're done, be sure to help the next paddler in their search by submitting a review!
Best All-Around SUPs of 2022
- 10'6" Beach Performer by TAHE
- Shoreline SUP by RAVE Sports
- 10'6" Ride MSL by Red Paddle Co.
- 10'0 Beach Cross by TAHE
- Performer 11' 2022 by Body Glove
- 11'2" All Day by Grey Duck
- 10'8" X 33" iGO by Starboard SUP
- Waterwalker 11' Paddle Board Package by Thurso Surf
- Breeze Aero by BOTE Boards
- Kahuna by Kaku Kayak
If you’re looking for a board to be equally at home surfing a wave as is relaxing on the local lake, look no further than the Performer series. If you want a slightly longer board, the 11'6" Beach Performer is another paddler favorite.
TAHE has blended surf-inspired longboard outlines for solid wave performance with confidence-inspiring stability and a moderate rocker profile for versatility in flat-water conditions. Join the thousands of riders who’ve made the Performer series an international best-seller.
- More information about 10'6" Beach Performer
- View all products from TAHE
- Seating Configuration: Solo
- Surf-Inspired longboard surf shapes
- Attachment points and bungee on deck
- Ergo-Grip carry handle
- Moderate rocker profile and tapered rails
- Tough-Tec construction
- Soft and grippy EVA foam deck pad
- FCS II tool-free removable center fin
10'6" Beach Performer Reviews
This was the very first SUP…
Owned this for almost a…
Just ordered this board and…
Shoreline SUP
At 10'9” in length and weighing 26.6lbs, the Shoreline is perfect for casual lake or flat-water paddlers. This lightweight design allows the board easy portability and handling. For best results, the Shoreline has the capacity to hold anyone up to 210lbs. Each board comes equipped with a standard 10” removable bottom fin as well as an easy-to-use elastic cargo strap to keep your life jacket tied down and accessible. The embossed diamond pattern on the EVA deck will give you the cushion and grip that you need to stay on the water all day long!
- More information about Shoreline SUP
- View all products from RAVE Sports
Shoreline SUP Reviews
No one has submitted a review yet for the Shoreline SUP. Please help out the community and share your experience!
10'6" Ride MSL
So, you need an inflatable paddle board that will see you right in all conditions. Well, look no further. Red Paddle Co’s multi-award-winning Ride 10’6” is Red Paddle Co's most popular board.
Imagine how at ease you’ll feel paddling out to sea on this versatile board. It offers excellent durability along with superior stability, so can withstand even the wildest of water adventures.
This board is designed to glide over water in all conditions. Whether you feel like a leisurely paddle on the lake with friends, or an action-packed adventure in head-high surf, this board offers a smooth and predictable ride. No matter what type of rider you are, you’ll have endless fun on this all-round board. It’s 120mm/4.7’’ thick, providing incredible stiffness that doesn’t compromise on performance.
- Structure: Inflatable
- Skill Level: Beginner
10'6" Ride MSL Reviews
Decent all around board.…
We tried out several boards…
This is a perfect SUP board…
10'0 Beach Cross
An ultra-stable platform equally suited for first-timers, family fun, fitness, yoga, fishing or whatever your next SUP adventure may be.
The unique ‘hybrid’ design of the Cross, also available as the 11' Beach Cross, features a keeled nose for excellent tracking, full rail-to-rail volume for enhanced stability and maximum use of the entire deck, and a full waterline to increase speed and efficiency. Numerous attachment points for securing accessories and deck rigging come standard on all Cross models.
- More information about 10'0 Beach Cross
- Keeled nose
- Molded EPS Foam Core
- FCS II Fin
- Foam Traction Pad
- Attachment points
- Ultra-Durable external shell
10'0 Beach Cross Reviews
The board is great, however…
This is an interesting…
I bought my Bic Ace Tec…
Performer 11' 2022
The Performer is back and better than ever. In addition to a new and improved overall shape, a wood grain ClearTek™ drop-stitch, and laser engraved foot placement guides, this year it's about more than just the board. Starting in 2022, we are partnering with One Tree Planted to plant a tree for every Performer sold, allowing you to give back to the planet with your purchase. Whether you are a novice paddler or an expert, we hope the new Performer inspires you to adventure.
- More information about Performer 11' 2022
- View all products from Body Glove
- New for 2022 - Electric pump included
- New wider shape for an increased average board width
- Woodgrain Clear Tek™ drop-stitch
- Reinforced nose bumper
- Tow point on nose
- Action camera attachment
- Front cargo bungee with stability harness
- Logo-embossed EVA traction pad
- Laser engraved foot placement guides
- Patented multi-functional carry handle/water bottle holder
- Cooler D-ring attachment points
- Triple true tracking durable fin design
- Package includes: 3-piece paddle, electric pump, high-pressure dual-action hand pump, coil ankle leash, cell phone dry bag, repair kit, and storage backpack
Performer 11' 2022 Reviews
11'2" All Day
The 11’2” All Day is a classic all-around shape that stands the test of time. This is a super stable board with good glide and load carrying capacity, making it a great choice for riders of all sizes and abilities. If your perfect day includes cruising the lake, going for a swim, catching some rays (or a few Z’s), and taking your four-legged friend along with you, this board may be your perfect match.
- More information about 11'2" All Day
- View all products from Grey Duck
- Skill Level: Beginner, Advanced
- 10” center fin with double FUTURE sides
- GORE no maintenance vent
- Ergo Handle for easy carrying
- GoPro camera mount
- Six point tie down system for carrying accessories
11'2" All Day Reviews
Great, fast, stable board. We…
This has been a great board.…
Learned of this company while…
10'8" X 33" iGO
The iGO inflatable paddle boards are known for being steady, having good speed and being super easy to turn while stepping back onto the wide tail area. The board’s straight outline helps to paddle straight and you can paddle more strokes on one side before you need to swap over, which also helps comfort and even increases the overall speed. This is the perfect paddle board range option for first-time paddlers, families with pets and anyone who wants less fuss and more enjoyable water time anywhere.
- More information about 10'8" X 33" iGO
- View all products from Starboard SUP
- Heat welded rails
- Outline shape
- 2-in-1 Shoulder carry strap
- Bungee tie-down
- Flat carry handle
- Pump included
- Cover bag included
- Lightweight leash included
- Windsurf option available
10'8" X 33" iGO Reviews
Purchased this board in the…
Thurso Surf Waterwalker is an All-around inflatable paddle board designed for all paddlers, skill levels, and water conditions. By uniquely incorporating a touring shape to the conventional all-around contour, the Waterwalker offers the best of both worlds: it is extremely stable and forgiving in most water conditions, and can travel effortlessly for long distance paddling trips.
Waterwalker 11' Paddle Board Package Reviews
I have this board in the…
Love the look. Love how rigid…
This is the first board that…
Breeze Aero
With a 33” width, the Breeze Aero 10'8" provides ample stability to ensure whether you are learning to paddle or an avid paddler looking for the lightest paddle board, you will have a great time.
- More information about Breeze Aero
- View all products from BOTE Boards
Breeze Aero Reviews
The Breeze is a great…
This inflatable is eveything…
Most amazing inflatable, had…
Kahuna
The Kahuna from Kaku Kayak has been the most popular fishing hybrid on the market among water sports enthusiasts since its debut in 2015. The Kahuna is a unique vessel that features a Kaku-designed modified-V Hull. Due to its great stability and paddling efficiency, the Kahuna can be paddled as a SUP or a kayak. Paddlers have found many different ways to customize the Kahuna, ranging from rigs for simple recreation to more sophisticated prostyle setups for fishing. Due to the great success of previous Kahuna versions, Kaku Kayak Owner Kevin Hawkins decided to keep the previous hull design.
The new Kahuna offers extreme stability, versatility and durability. Mount coolers, seats, storage boxes, rod holders and more to its rugged frame. It’s the first paddle craft of its kind to offer fully integrated mounting for the Micro Power Pole Shallow Water Anchor!
- More information about Kahuna
- View all products from Kaku Kayak
- Skill Level: Intermediate
- Carry handle
- Bungee
- Tie downs
- Powerpole integrated mount
- 8" round hatch
- 18" recessed top-load aluminum gear tracks
- Three inserts for optional 12" gear track
Kahuna Reviews
Most reviews here come after…
In the market and had an…
The best of both worlds with…
Although we wish we could spend all day, every day in our kayaks, we land dwellers know better. Whether…
Pedal Drive Fishing Kayaks are easily one of the fastest growing categories of watercraft in recent…
