Best Kayak Wall Racks
Wall racks are one of the most popular choices for storing your kayaks, canoes, or SUPs. Mounted either inside or outside and using a range of lightweight, but strong materials, like J-Cradles, mounting hardware, and straps, there are a number of great options to choose from.
Below is a list of some of the most popular kayak wall racks from brands like Sparehand Paddlesports, Malone, Suspenz, Seattle Sports, and more. For even more options, be sure to check out the full Kayak Wall Racks gear guide.
Fortunately, the paddling community has been testing, paddling, and reviewing wall racks and other storage options for over twenty years. By leveraging the reviews and experience that's been shared by thousands of your fellow paddlers, you can help narrow down the various wall rack options to find the best storage solution for you.
Your Review Matters
Best Kayak Wall Racks of 2021
- JDock™ Kayak Storage System by Malone Auto Racks
- Kayak Wall Cradles by Seattle Sports
- Wall Mounted Single Kayak Storage Rack by Sparehand Paddlesports
- Kayak Condo by Talic Storage Systems
- Kayak J-Storage Cradles by Oak Orchard Canoe Kayak Experts
- Big EZ Wall Mount Rack by Suspenz Storage & Transport
- Deluxe Double-Up Wall Cradles by Seattle Sports
- JAY Wall Mount Rack by Suspenz Storage & Transport
- Wall Mounted Storage Racks by The Dock Doctors
A smart choice for safely storing canoes, kayaks and roof boxes. The JDock™ is a wall mount system capable of storing two kayaks inside or outside. 200 LB capacity heavy duty all steel wall cradles with corrosion resistant powder coating. Comes complete with 12' load straps, mounting hardware and a Lifetime Limited Warranty.
- More information about JDock™ Kayak Storage System
- View all products from Malone Auto Racks
- Material Description: Corrosion resistant for extended life
- Two kayak storage capacity
- Large enough to store a roof box or canoe
- Includes all required mounting hardware and 12' cam buckle load straps
- Approved for inside or outside installation
- Corrosion resistant for extended life
- Lifetime Limited Warranty
JDock™ Kayak Storage System Reviews
I use the Malone J Dock to…
The JDock looks nice but,…
I absolutely love this…
Kayak Wall Cradles
Store your kayak in a snap with these easy-mount wall cradles. Built with strong yet lightweight powder-coated steel, the cradles come with mounting lag bolts for quick and easy installation.
- More information about Kayak Wall Cradles
- Material Description: Powder-coated steel
- Top selling kayak storage solution
- Strong, yet lightweight powder-coated steel
- Mounting hardware included
- Sold in pairs
- Compatible with Cradle Lock
Kayak Wall Cradles Reviews
No one has submitted a review yet for the Kayak Wall Cradles. Please help out the community and share your experience!
SpareHand KC-10 is the best value for storing your boat on your wall- Sparehand KC-10 wall rack and can be mounted anywhere that has wall stud or anchor to cement block walls (anchor included). This simple system is very strong and easy to install. Also comes with safety strap to secure your kayak.
- More information about Wall Mounted Single Kayak Storage Rack
- Wall-mount kayak storage rack
- Steel construction with padded arms
- Stores a boat on your wall
- Dimensions: 2.5W x 24D x 20H inches
Wall Mounted Single Kayak Storage Rack Reviews
No one has submitted a review yet for the Wall Mounted Single Kayak Storage Rack. Please help out the community and share your experience!
Kayak Condo
The Talic Kayak Condo – Wall Mounted Storage for Kayaks is convenient, accommodating, and best of all, affordable! The very thick and soft 2 inch wide webbing conforms to the shape of your boat which means there won’t be any pressure points to dent or scratch your boat. You can look forward to years of maintenance free storage. All your kayaks will rest comfortably, sure to be in excellent condition and ready for yet another day’s adventure. There are three models to choose from and each one is strong enough to hold boats that are 100 pounds each. Kayak Condo 3 can hold three boats each weighing 100 pounds – now that’s strong! Recommended for kayaks under 100 pounds, and about 29 inches wide or less. Not recommended for outdoor use. Easy to install, easy to use. You’ll have peace of mind, knowing that your boats will have the best rest available, and at such a great price. If you plan to mount the Kayak Condo onto a masonry wall you will need to purchase a Masonry Wall Mounting Kit.
Prices range from $109.95 to $274.95.
- Prices range from $109.95 to $274.95
Kayak Condo Reviews
bought the kayak rack 2…
I had the idea that putting…
I recently purchased and…
No bent, 1 inch aluminum tubing here! Same basic shape as the incredible J-CRADLES, but at a reduced price to only fit a blank wall area or outdoor, inground post. Made from Heavy Duty, 3" wide, No-Rust Steel. Designed to hold a single or tandem kayak. Deluxe 3/4" Thick Real Rubber Padding! 3 inch wide flat rubber area will hold your boat carefully. Easy one person load - No dangerous ropes or pulleys. Set of two includes 2 HD straps and mounting screws
Kayak J-Storage Cradles Reviews
No one has submitted a review yet for the Kayak J-Storage Cradles. Please help out the community and share your experience!
Watercraft rests on nylon covered foam pad. Stores boats & boards on their side at their strongest point. Adjustable safety straps hold your boat securely in place. UV protected straps, fabrics and plastic parts. Includes 2 Big EZ Arms with Safety Straps & Mounting Hardware.
Available in Marine Grade (Black) - $104.95
- More information about Big EZ Wall Mount Rack
- Material Description: Powder-coated steel frame
- Compatible with Suspenz Free-Standing Storage Systems
- Extends 28” from the wall
- Holds up to 150 lbs.
Big EZ Wall Mount Rack Reviews
No one has submitted a review yet for the Big EZ Wall Mount Rack. Please help out the community and share your experience!
Deluxe Double-Up Wall Cradles make storing your boats and paddle a cinch! Wall mounted heavy-duty steel cradles allow you to store two boats with one set of cradles. Easily fold up the cradles when not in use. Includes two cinch straps for secondary boat storage. All mounting hardware included.
- More information about Deluxe Double-Up Wall Cradles
- Wall mounted heavy-duty steel cradles
- Store 2 boats! Use the included cinch straps to store a second boat
- Pivoting arms allow for fold up storage when not in use
- Built in cleats designed for storing your paddle
- All mounting hardware included
Deluxe Double-Up Wall Cradles Reviews
No one has submitted a review yet for the Deluxe Double-Up Wall Cradles. Please help out the community and share your experience!
JAY Wall Mount Rack
The BEST way to store your boat is to suspend it on straps so there are NO PRESSURE POINTS, it never touches a hard surface! This JAY Rack will cradle your boat and distribute its weight evenly. Included in box: 2 JAY Arms with Safety Straps & Wall Mounting Hardware.
- Material Description: Powder coated steel frame
- Extends 22" from the wall, Height: 26”
- Boat rest on the exclusive CSS (Cradling Strap System) – No pressure points; protects against hull distortion
- Store kayaks on their SIDE at its strongest point
- Adjustable straps to suspend your kayak or SUP correctly
- Module arm that can also attach to Free-Standing rack
- Stores boats up to 125 lbs.
JAY Wall Mount Rack Reviews
I purchased the Suspenz…
Very Good racks, nice wide…
Lightweight aluminum, wall-mounted rack for storage of canoes, kayaks or SUP boards, and other small crafts. Mount in your garage, storage shed, basement our house exterior. Rack comes standard with 6 arms to store 3 crafts. Features adjustable height arms with vinyl hull guards and end caps with built in tie-down openings. Add additional arms to store more crafts or items such as ladders. Available in aluminum or powder-coated black finish.
- Rack Dimensions: 38" Deep x 84" High x Variable Width (width is variable depending upon installation, depth is from wall to end of arm). Arm length: 35"
Wall Mounted Storage Racks Reviews
No one has submitted a review yet for the Wall Mounted Storage Racks. Please help out the community and share your experience!
Lots of paddlers spend a good amount of time figuring out which kayak they are going to buy. A lot less…
Portable kayak stands are amazing for on-the-go work stands or for washing and rigging your boat when…
No, I'm not speaking of jet skis, charter captains, air boats, and tourists. OK, they all can fall in to…
