Niphean Clovis Point Inflatable Paddle Board Review
Inflatables like Niphean’s 10’ 6” Clovis Point have been a game changer for those looking to dip a toe into the standup paddleboard waters, add a water toy to the family cabin, or just lack the space — at home or while transporting — to make a rigid board a viable option. Built with drop-stitch construction and a military-grade PVC skin, it’s durable, puncture-resistant and stable enough to satisfy a wide variety of riders.
Toss in a few extras — like a choice of fins, kayak-conversion seat, convertible paddle, pump, and a stability-enhancing StabilTrac Fin — and you’ve got a package that, at less than $270, just may be the epitome of bang for the buck.
Unpacking The Clovis
Like most iSUPs, Niphean packs everything away into a backpack, in this case a rectangular 35” x 16” x 10” design weighing in around 19 pounds. Like most bags at this price point, it’s relatively basic, but the target audience isn’t likely hiking into remote waters. More often than not, the pack will be tossed in a car trunk or backseat, lugged in and out of the house, or just counted on to keep everything together, a task for which the Niphean pack is more than capable.
Contents include the 10’ 6” Clovis board, finished in an attractive light-wood pattern accented topside with a pop of white and mint-colored EVA foam traction pad. That same mint is carried over onto both paddle blades and handle, manual pump, and a criss-crossed bungee run through D-rings forward to secure items like a lifejacket or dry bag. You also get a trio of detachable fins (two 4 1/2” side fins, one 8 1/2” center fin), the 14 3/4” centerboard-like StabilTrac Fin, inflatable seat with backrest and tie-down straps, three-piece height-adjustable paddle with additional blade, leash, manual pump, repair kit with valve wrench and patches along with a waterproof phone bag.
Inflate the board to the recommended 12-15 psi, insert your choice of fins into their respective slide-in boxes, attach the leash and you’re ready to hit the water. Center and aft carry handles provide a convenient handhold for carrying the board or pulling up onto the sand. An additional handle at the tip would be appreciated. The adjustable aluminum paddle is marked in both inches and centimeters and extends to a max height of nearly 7 feet.
If the set has a shortcoming, it’s one shared by many affordable iSUPs—a lightweight manual pump. Its single-action design means air flows into the board only on the downward stroke, increasing inflation time. We also have concerns about the long-term durability of its plastic construction. Treat it with care, but better yet ,spend a few extra dollars for an electric pump. Niphean’s own model will fully pump up the board and shut off at the desired PSI. Even cheap electric pumps can mostly inflate an iSUP; the manual pump can then be used to add those last few pounds for the necessary rigidity quickly. They’re a huge time saver and take the single greatest headache out of living with an inflatable board.
Let’s Paddle!
On the water, we noted the 33-inch wide Clovis offered the necessary stability for a target audience that will include total newbies, younger paddlers, families, and maybe the occasional yoga enthusiast.
Dial in stability and tracking via Niphean’s choice of fins. We suggest the longer center fin as your go-to for general use and tracking in flatter water. The shorter side fins can be added to improve maneuverability, or, used alone in extremely shallow waters if you don’t mind losing a little tracking ability.
One of the biggest surprises with the Clovis Point was how stable it felt on the water, and a big part of that comes down to Niphean’s StabilTrac Fin system. Similar to a boat's centerboard and positioned in the board’s geometric center of gravity, Niphean says the StabilTrac Fin counteracts lateral torque from body movement and that the fin-like wing enhances longitudinal rigidity. This isn’t your average removable fin. Shaped more like a small wing than a blade, this patented center fin design dramatically boosts lateral stability. For first-timers and families, that means fewer wobbles and less tipping, especially when climbing on from the dock or paddling in light chop.
Where some beginner boards can feel squirrelly or require constant adjustment, the Clovis Point holds its line with minimal correction. We noted the StabilTrac Fin indeed made the board more stable and lessened crosswind-induced sideways drift. During testing, we tried removing the fin just to feel the difference, and the downgrade in balance was immediately noticeable. This fin really does make a difference, particularly for new paddlers who are still finding their footing or sharing the board with kids or pets.
For new paddlers, the StabilTrac Fin will eliminate some frustration, but it does introduce a pivot point near the center of the board. Without the StabilTrac Fin, we could easily take six to eight strokes on one side without the board drifting significantly off its line. However, with it installed, that was reduced to just a few strokes before we were forced to switch sides to correct.
This experience may vary by skill level—Niphean’s in-house testing suggests that beginners typically see improved tracking with the StabilTrac Fin. At the same time, I, as an experienced paddler, found it less beneficial, as proper paddle technique allowed me to maintain a straight line without it. It’s good to have options: new paddlers can use the StabilTrac Fin to build confidence, then remove it as they develop their skills and begin prioritizing agility on the water.
Lastly, at nearly 15 inches in depth, paddlers also need to remember that the StabilTrac Fin is below them when coming into the beach or traversing very shallow waters.
Another family-friendly touch is the Ergonomic Inflatable Paddle Board Seat, which turns the Clovis Point into a sit-on-top kayak hybrid. While the lumbar support and rear mesh storage are nice, what really stands out is the seat’s comfort during longer paddles. The contoured backrest offers real posture support, not just a floppy cushion, making it ideal for those who want to stay seated for confidence or convenience. Whether you're easing into paddling or just prefer a kayak-style setup, it adds significant versatility—and comfort—to the overall package.
A mesh pocket on the backside keeps items like water bottle or sunscreen close at hand. Create a kayak paddle by replacing the handle with an additional paddle blade, or shorten the paddle to resemble a canoe.
Final Impression
With its combination of stylish design and overall construction details, the Clovis may be affordable, but it’s important to note it never looks—or feels—cheap. It also doesn’t make you feel like you’re on a bargain board underway, holding a nice line and offering plenty of stability.
Yes, at this price point you have to expect a few tradeoffs — the relatively minimalist backpack and manual pump come to mind — but we think beginner-to-intermediate riders, families looking to increase their enjoyment out of that waterfront escape, or those who desire (or require) an easily transportable SUP will get a lot of mileage out of the investment. Especially given the ability to also easily convert the board into a kayak-style hybrid and increase its versatility.
All in all, that’s a pretty good mix of features for only $269.99.
Paddling.com Reader Discount Code: From now through July 31, readers can use code PADDING05NP to save 10% Shop now on Niphean’s Amazon store and enjoy an exclusive limited-time discount
Hi, I'm Jimmy Blakeney, with Standup.paddling.com, here to talk to you about the great sport of standup…
Pivot turns are a great way to turn your board and you can do them when you're stationary or moving. The…
Jim Terrell from Quickblade focuses on these 4 components of SUP: - Hand Position on paddle, Foot…
One of the most common, if not the most common, faux pas in paddle boarding is to hold and use…
