Best Dry Bags of 2023
There is nothing worse than wet gear, so check out these great dry bags ranging from 5L to 105L. These top-of-the-line dry bags will keep your contents safe, protected, and arid. The right size, material, and closure-type will be different for each paddler and outing, so this list has something for everyone at different price points.
Baja Dry Bag
Proven on both water and land-based adventures around the world, Baja Bags provide versatile and durable protection. Made with 19 oz. vinyl sides and a heavy-duty 30 oz. bottom, they can withstand just about any abuse Mother Nature, or your crew, can dish out. Baja Bags close with the Dry Seal™ roll-top Closure and have an attached D-ring for securing inside a raft or on top of a luggage rack.
  • Material Description: 19-oz. scrim-reinforced vinyl body, 30-oz. scrim-reinforced vinyl bottom
  • Proven Design: All-purpose, reliable protection for your gear.
  • Built Tough: 19 oz. scrim-reinforced vinyl side with heavy duty 30 oz. scrim-reinforced vinyl bottom
  • Reliable Protection: Dry Seal™ roll-top Closure ensures the best watertight seal possible.
  • Price range: $19.95-$39.95
  • Size Range: 5L - 55L
Baja Dry Bag Reviews
5 out of 5 stars
(2 Consumer Reviews)
If you are looking for the…
If you are looking for the older Sealline See model they are no longer branded by that name. In 2020 they are currently made as the Baja View. I got my first SealLine bags in… read full review
Dry bag made of thick plastic…
Dry bag made of thick plastic rubbery material, likely older model. 10 liters in size. It and two others have served me well for over a decade. They are well made, reliable, … read full review
Glacier Dry Bag
With tough wrap bottom protection, Glacier Clears are the most durable clear dry bags on the market. Constructed with rugged 20oz. clear vinyl, locating gear and equipment is a snap. Color coded by size, or get the whole collection in lime green! Sizes range from XS(5L) to XL(55L):
  • XS- 5 Liter Dimensions: 10in H x 6in DIA, Capacity: 300ci/5L
  • SM- 10 Liter Dimensions: 15in H x 7.5in DIA, Capacity: 600ci/10L
  • MD- 20 Liter Dimensions: 18in H x 9.5in DIA, Capacity: 1275ci/20L
  • LG- 40 Liter Dimensions: 25in H x 11.5in DIA, Capacity: 2500ci/40L
  • XL- 55 Liter Dimensions: 28in H x 12.5in DIA, Capacity: 3500ci/55L
  • Material Description: 20oz clear vinyl body
  • RF welded seams
  • Abrasion resistant base
  • 3-roll top close
  • Round base
  • D-ring for tie-down and lashing
  • Color coded by size
Glacier Dry Bag Reviews
5 out of 5 stars
As a sea kayaker who paddles…
As a sea kayaker who paddles day and multiday trips, a see through dry bag is the only way to go in my opinion - I can see what's in the bag. I have a 5L Glacier Bay and have… read full review
I'm new to kayaking and…
I'm new to kayaking and recently took a 4.5-hour kayaking course that included rolling my kayak, but I managed to roll it before we got to that part of the lesson! I had my … read full review
NRS 65L Bill's Bag Dry Bags
by NRS
Since 1977, outfitters, guides and weekend warriors have relied on Bill's Bags to keep their overnight gear dry trip after trip, year after year. This midsize dry bag can compact enough to fit in overhead compartments of most airlines and is the perfect size for weekend and overnight trips. Constructed with heavy-duty 21 oz PVC/polyester body with a reinforced bottom of 34 oz PVC, the Bill's Bags will outlast a generation worth of adventures. Expandable for over 3900 cubic inches of storage capacity but can be cinched down with four compression straps to compact and stabilize gear. The adjustable backpack harness with padded shoulder straps makes carrying your gear around rapids or into a secluded camp easy and comfortable.
  • Material Description: 21 oz. PVC/polyester body, 34 oz. PVC/polyester bottom
  • Aluminum fasteners on the compression straps increase durability and eliminate busted buckles
  • StormStrip™ closure system provides a confident seal and allows for easy top loading access
NRS 65L Bill's Bag Dry Bags Reviews
5 out of 5 stars
(1 Consumer Reviews)
I purchased the NRS 65L…
I purchased the NRS 65L Bill's Bag for canoe/kayak trips in northern Minnesota. I already owned a few dry bags but wanted something with straps like a backpack in case I ever… read full review
20L Bluewater Roll Top Dry Bags
Fully welded construction for unmatched durability with waterproof label window so you can see what's inside without letting in the elements. Unique cube design packs together tightly and won't roll around on deck.
  • Material Description: 210 denier ripstop nylon; TPU coated
  • Length: 27.4"
  • Width: 15.3"
  • Depth: 5.9"
  • Weight: 6.5 oz
20L Bluewater Roll Top Dry Bags Reviews
(0 Consumer Reviews)
No one has submitted a review yet for the 20L Bluewater Roll Top Dry Bags. Please help out the community and share your experience!
Explorer Dry Bag
The Classic dry bag built to withstand serious abuse. Domestically manufactured with high quality 19oz. vinyl and radio-frequency welded seams, the Explorer Dry Bag is our original time-tested, user-approved dry stuff sack. Sizing comes XS(5L) up to XL(55L):
  • XS- 5L Dimensions: 10in H x 6in DIA • Capacity: 300ci/5L
  • SM- 10L Dimensions: 15in H x 7.5in DIA • Capacity: 600ci/10L
  • MD- 20L Dimensions: 18in H x 9.5in DIA • Capacity: 1275ci/20L
  • LG- 40L Dimensions: 25in H x 11.5in DIA • Capacity: 2500ci/40L
  • XL- 55L Dimensions: 28in H x 12.5in DIA • Capacity: 3500ci/55L
  • Material Description: 19oz vinyl body
  • RF welded seams
  • 3-roll top close
  • Easy load round base
Explorer Dry Bag Reviews
4 out of 5 stars
Good construction and seems…
Good construction and seems sturdy/ Sturdy Seams with quality materials used, kept my gear nice and dry as its supposed to. I like the fact this is 'backpackable' and its rea… read full review
eVac Dry Sack
The eVAC™ Dry Sack uses waterproof, air permeable eVENT® fabric on the base for valve-free air expelling, allowing compact packing. Instead of straps for compression, you just roll the sack down and air is pushed out of the base to save space and weight. The sack is oval-shaped to resist rolling when laid on their side. eVac Dry Saks work really well for any compressible item (sleeping bags, clothing) which needs to be squeezed down as small as possible yet stay dry. Air just squeezes out through the eVent base, but water can’t get in.
  • Material Description: 70 Denier nylon
  • Available in 3L,5L,8L,13L,20L,35L,65L
eVac Dry Sack Reviews
No one has submitted a review yet for the eVac Dry Sack. Please help out the community and share your experience!
Lightweight Dry Sack
A less expensive and less bulky alternative to traditional dry bags. You can squash these into spots ordinary heavy dry bags won't go. Fits into little corners of a sea kayak or light enough to take backpacking or adventure traveling. Suitable to keep contents dry in any wet situation where the bag is not submerged. Lightweight Dry Sacks are made of 70 Denier nylon. They are tough, yet still light enough to work well in backpacking use. The flexible fabric makes them easy to stuff into tight areas – ideal bags for general boating / outdoor use.
  • (1L, 2L, 4L, 8L, 13L, 20L, 35L)
Lightweight Dry Sack Reviews
4 out of 5 stars
Used the sea to summit dry…
Used the sea to summit dry sacks for a Northern Tier scouting high adventure. We went 100 miles in weather that included rain and storms. We wanted and had to swim to shore. … read full review
LocoDry DownUnder ZipDuff
New for 2019 - A seriously hardcore, waterproof, duffel/backpack. Gas tight, T-style, waterproof zipper and heavy-duty 600D PU – coated material. Giving you the confidence to take on the gnarliest of water adventures. Featuring the new Ergo LocoModiv™ shoulder straps with the patented UniLoop™ system – allowing you to easily swap between the included black and neon green breathable, strong, grippy, stretchy, and customizable shoulder straps. Easily switch between duffel style grip or throw it on your back for a convenient and comfortable portage. DownUnder ZipDuff gives you the waterproof protection you need at the cost you want. Available in 60 L ($174.95) and 90 L sizes ($184.95).
  • Material Description: Heavy duty 600D PU coated nylon
  • Gas-tight, waterproof, zipper
  • Includes 2 sets of Ergo silicone shoulder straps (black & neon green)
LocoDry DownUnder ZipDuff Reviews
No one has submitted a review yet for the LocoDry DownUnder ZipDuff. Please help out the community and share your experience!
NRS High Roll Duffel Dry Bag
by NRS
The NRS High Roll Duffel Dry Bags deliver the same rugged dependability as the legendary Bill's Bags, but in a duffel-style design that makes packing your gear, and finding it later, easy. The heavy-duty 21 oz PVC/polyester construction can handle the wear and tear of any rugged outdoor adventure. The fold-down StormStrip™ closure system seals water out of the duffel. Fold (rather than roll) from the top, at least three times, then hook the aluminum fasteners through webbing loops on the sides of the bag. Cinch down to add extra pressure on the seal for the driest possible protection. Webbing chains offer ample attachment points to secure other items to the bag.
  • Prices starting from $109.95 for the 35L size
  • Available in 35L, 70L & 105L sizes
NRS High Roll Duffel Dry Bag Reviews
No one has submitted a review yet for the NRS High Roll Duffel Dry Bag. Please help out the community and share your experience!
You'd think choosing a canoe pack, since it's only generally used for carrying a large volume of gear…
One of the great companion activities associated with paddling is photography. The quietness of the…
