429 Too Many Requests
openresty
Leg Workout for Paddling | Paddling.com 429 Too Many Requests
openresty
This workout routine specifically targets the legs, and can be a part of a full body routine to be done three days a week. It's a great routine for athletes in almost any sport. For the paddler, it will build endurance, muscle, balance and coordination.
Grab a paddle, and let's get started!
Squats - Basic (balance, strength)
Muscles Used: Quadriceps, Gluteus Maximus
Used In: Loading, Lifting and Portage
Sets: 3
Reps: 20
Begin by standing upright with the feet shoulder width apart. Point the toes outward at a 45-degree angle.
Use a paddle, broomstick or dowel, placed in front of you, for balance.
While squeezing your abs and thighs, start the exercise by standing on your toes, and then squat down as if sitting on a chair. Inhale on the way down.
Keep your back straight and the shoulders and chest in line with the hips. Stop when your thighs are parallel to the floor.
Do not lean forward or rock your chest out over the knees.
Now, pressing with the thighs, push back up to the starting position. Exhale as you push. Do not pull yourself back up using your arms! The paddle is only for balance.
This is an advanced version of the same exercise and requires more balance and strength.
Begin, as before, with the same foot position. Place the paddle over your head, as shown in the picture.
Go into the squatting position while keeping the paddle above your head.
As you squat, keep the paddle in line with the shoulders and spine. This means it will travel backward, behind the head, for balance.
A tip for balance: Arch the back and extend your chest out over the thighs.
Leg Extentions - Isolation (strength, muscle tone)
Used In: Loading, unloading and portage
Sets: 3
Reps: 20
Adjust the seat so the knee is even with the point of rotation of the machine.
Also, adjust the shin pad so it rests just above the ankle.
Use light enough weight to do 20 reps.
Take a deep breath...
....and then, extend the leg up as you exhale.
Once fully extended, flex the quadriceps (thighs) at the top of the stroke and hold the position for a count of 3 seconds.
Return to the start position but do not let the weights touch. This will keep weight on the quadriceps through out the exercise.
Leg Curls - Isolation (strength, muscle tone)
Muscles Used: Hamsrings, Gluteus Maximus
Used In: Loading, lifting and portage
Sets: 3
Reps: 20
Adjust the body so the knee is even with the point of rotation of the machine.
Also, adjust the calf pad so it rests just above the ankle. Hold the handles of the machine with the head up, looking forward.
Use light enough weight to do 20 reps. Take a deep breath...
... and then, flex the hamstrings and curl the legs up as you exhale.
At the top of the curl, squeeze the hamstrings and glutes (the muscles in your butt) and hold the position for a count of 3 seconds.
Then return to the starting position. Do not let the weights touch as you lower your legs.
These great leg exercises, when added to your full body routine will help build muscle and stamina.
This exercise routine specifically targets the arms, and can be completed as part of a full body routine…
This quick exercise routine targets the shoulder muscles, essential for all paddling maneuvers. It is…
openresty
openresty
