Hip Snaps: Strength & Balance
Paddling.net continues the series of specific exercises for paddlers, but with a twist this time (or should we say ball). For the following exercise segments, you'll be encouraged to use a Pilates Ball.
Previously, we looked at strengthing your abs using the C Lean exercise while on the pilates ball. This following exercise will train the abs for good form when doing Hip Snaps. Hip snaps are needed for overall kayak control, righting and recovery. You can't do a sweep or "C" to "C" roll without it.
This exercise is done to train the obliques for strong, quick hips snap on demand. While doing this routine, squeeze your abs to hold the position. Go for the burn!
Pilates Ball & Hip Snaps: (Balance & Ab Training)
Begin by sitting ontop of the pilates ball (inflate the ball so it is very firm) with a paddle, broom stick or long dowel in hand.
- Start the exercise with both feet about shoulder width apart or wider if needed for balance.
- Place the paddle above your head with the forearms vertical.
- Now raise the hip by using the oblique muscles of the abs while keeping the head and shoulders still.
- This is the same as the J lean but don't hold the position.
- Go straight to the other side by raising the other hip. Remember to keep the head and shoulders still.
- Alternate sides, back and forth, as quickly as you can. As you raise one hip, push your butt, on the opposite side, into the Pilates ball.
Do this fifteen times, counting on one side as you go. Stop. Then repeat.
Go for three sets.
WASHINGTON, D.C. (March 20, 2018). The U.S. Coast Guard’s National On-Water Standards (NOWS)…
A post shared by Paddling.com (@paddling_com) on Sep 28, 2017 at 11:06am PDT
Paddling.net concludes the series of Tony Kramer's specific exercises for paddlers. For the following…
