Canoeing Into The Wind Solo
Learn how to paddle into the wind solo by distributing your weight, having the proper trajectory and using the correct strokes in order to paddle as fast and efficient as possible.
I grew up in an area of Canada that is often referred to as canoe country. The landscape is dotted with…
When paddling solo you can move backward in a straight line by using a combination of back strokes and…
