C-Leans: Strength & Balance
Paddling.net continues the series of specific exercises for paddlers, but with a twist this time (or should we say ball). For the following exercise segments, you'll be encouraged to use a Pilates Ball.
Previously, we looked at strengthing your abs using the J Lean exercise while on the pilates ball. This following exercise will train the abs for good form when doing C leans. While doing this routine, squeeze your abs to hold the position. Go for the burn!
Pilates Ball & C-Leans: (Balance & Ab Training)
Begin by sitting ontop of the pilates ball (inflate the ball so it is very firm) with a paddle, broom stick or long dowel in hand.
- Start the exercise with both feet about shoulder width apart or wider if needed for balance.
- Place the paddle across the top chest just above the collar bone.
- Place the paddle in a "high brace" position keeping the elbows tucked close to the body.
- On your bracing side (where the paddle meets the water),make the letter C with your body. Raise the hip by using the oblique muscles of the abs. Try to lay your head over on the shoulder.
- Hold this position for five seconds.
- Swap sides by switching your "high brace" and raising the hip.
- While changing sides, lower your shoulder and lay your head over.
- Hold this position for five seconds and then go back to the other side.
Do this ten times, holding your C lean for five seconds on each turn.
Fitness for paddling has been on my mind a lot lately and I thought maybe my story on why I've been…
As an instructor I try to provide experiences that simulate more difficult conditions while still being…
