Ab Crunches
Paddling.net concludes the series of Tony Kramer's specific exercises for paddlers. For the following exercise segments, you'll be encouraged to use a Pilates Ball.
Previously, we looked at strengthing your obliques and ab muscles using the Hip Snap exercise while on the pilates ball. This following exercise will strengthen the upper and lower abs specifically. Ab muscles are used in any paddling stroke.
These crunches will finish up your ab routine. In all of the other exercises you have been using the obliques. And now, the crunches will aid in training the upper and lower abs as well.
Pilates Ball & Ab Crunches: (Balance & Ab Training)
Begin by sitting ontop of the pilates ball (inflate the ball so it is very firm).
- Start the exercise with both feet about shoulder width apart or wider if needed for balance.
- Lay back over the ball, your hands behind your head, letting your back arch over the top. Feel the stretch in your abdominals.
- Slowly squeeze your abs to "crunch up" into a sitting position.
Avoid a sudden "jerk" up, using your arms to pull you off the ball. - While keeping your abs tight, slowly lay back over the ball.
Repeat these steps for twenty reps. Do three sets and go for a good burn.
Fitness for paddling has been on my mind a lot lately and I thought maybe my story on why I've been…
