  • Wave Turns - Work Less, Surf More
Let's face it: canoes are big boats, and they can be difficult to paddle. The result is that we often work too hard paddling whitewater. When teaching open canoeing, I frequently point out the many opportunities to use water features to reduce the effort of paddling rapids. One of my favorites is the wave turn. Suppose you need to turn from facing downstream to facing upstream. Why take a half dozen strokes to turn your boat when you could use a breaking wave to do the work of spinning the canoe for you?
Wave turns are as much an exercise in water reading as they are in good boat control. To plan a wave turn, scan downstream looking for a breaking wave with a foam pile perpendicular to the current. The best foam piles have aerated water falling from the wave peak down to the wave trough. Small holes work too, but be careful to wave turn only on features that you also would feel comfortable surfing.
Photo 1. Approach the corner of a breaking wave by pointing the bow at about 45 degrees to the wave crest. In weaker currents you can open up the angle.
Photo 2. Keep to the shoulder of the wave so that once the bow strikes the foam pile the stern is still in the downstream current.
Photo 3. As the boat spins, keep the canoe tilt flat by tightening your legs against the thigh straps. Avoid bracing as you may catch your blade once the canoe spins upstream.
Photo 4. After the spin, you can front surf if you like, or ferry either direction to the next helpful feature on the river.
The secret to wave turns is boat position. Begin your approach by aiming your bow at the corner of the breaking wave so the bow points toward the foam pile. Accelerate gently so the bow of your canoe hits the white water at the top of the wave crest. The foam pile is not moving downstream and will catch and hold the bow of your canoe. The stern, which is still in the downstream current, will pass the stalled bow. The result is a spin that turns the canoe upstream. Spinning and catching the wave without the canoe sliding downstream requires that you engage a suitable foam pile with correct boat angle, speed and bow placement.
In some ways, spinning and stalling on a wave serves the same purpose as a mid-current eddy pool. What makes this move better is that you can stay on the wave and enjoy a front surf. The true benefit, though, is that you've halted your downstream momentum and are ready to stage your next move. You may decide to front ferry or (as shown) choose to change direction and S-turn to an eddy along shore. Both maneuvers will seem easy because the cross-current momentum, generated by the brief front surf, carries into your next move.
The wave turn offers all these benefits while requiring minimal strokes—in fact, I didn't mention one stroke in this entire article. Just stuff your bow into the corner of a breaking wave and let the river do the work. Reducing your effort by using water features, like waves and holes, is the key making paddling a canoe look easy. Have fun, and don't work too hard.
Andrew Westwood is a frequent contributor to Rapid and is an open canoe instructor at the Madawaska Kanu Centre.
Reprinted with permission from Rapid Magazine Spring 2004.
Rapid is a magazine dedicated to all whitewater paddlers. But the demographics of whitewater are such that the majority of paddlers are 25 to 45. Rapid’s colourful, pictorial look is a shift toward capturing the attention of the lifestyle-driven, hugely powerful and influential group of teens waiting in the wings. Rapid Magazine is proactively building the next generation of the whitewater paddling market. Read full articles online at www.rapidmagazineinc.com/rapid/.
