How to Rooftop Load Your Kayak
Need help loading your kayak onto the roof of your vehicle? Austin Kayak and ThatBassFishingDude demonstrate an easy way to get big kayaks onto any roof rack.
Loading Your Kayak
All you need are a rooftop rack, pool noodle, and ratchet strap. Start by putting your pool noodle through the ratchet strap. Attach that to your roof rack, and tighten it to create a saddle. This will allow you to lean your kayak on your vehicle without scratching it.
Next, line up your boat to the middle of the rack, and lean your boat against the vehicle. The front of the boat should be on the ground. Once you have it lined up properly, grab the front of your boat, push up, and rotate it onto the correct spot. Voila, you've successfully loaded your kayak onto the roof of your car!
Check out the best Car Rack Systems at Austin Kayak
Shop NowRelated Articles
Canoe storage is critical, not only for the offseason to protect your boat, but because space is limited…
Proper storage for your SUP is critical in protecting it when not in use. You'd be surprised at how many…
Before hopping in the car to head to your local REI dealer, you might ask yourself a few questions…
