How to Brace a SUP
SUP Low Bracing and SUP High Bracing
This is going to be really important to learn to navigate whitewater, it keeps you from falling off your board so it's very basic.
SUP Low Brace
The low brace uses the non-power face of the paddle. You are going to put this down on the water to the side of the board and just slap the water with the paddle. The low brace is a good way to stabilize you to keep you standing on your board.
SUP High Brace
Place the paddle out to the side of the board about 2-3 feet. Your going to slap the paddle as it hits the water and this is going to give you some stability. It will also pull your board a little bit towards the paddle which will help keep you in a straight line. This is a great stroke to combine with a forward stroke, or you can simply do one high brace after another until you have completed that part of the river.
Sometimes you want to go backwards; maybe because you've explored a narrow creek that's so narrow you…
I grew up in an area of Canada that is often referred to as canoe country. The landscape is dotted with…
One of the greatest things about kayaking is that pretty much anybody can hop in and do it. But you need…
